Update Values in xml files
tomgoertz
Post by tomgoertz »
How can I change a value in an xml file without using npm packages?
Example:
<order>
<jobs>
<job>
	<jobID>A</jobID>
	<fileName>*/abcdef.pdf</fileName>
</job>
<job>
	<jobID>B</jobID>
</job>
</jobs>
</order>
Job A and B have the same file name. In my flow the files are renamed to JobID_FileName. Now I would like to change the file name in the XML accordingly.
sander
Re: Update Values in xml files
Post by sander »
I would go with Saxon and an xslt:
Input:
<order>
<jobs>
<job>
	<jobID>A</jobID>
</job>
<job>
	<jobID>B</jobID>
</job>
</jobs>
</order>
XSLT:
<xsl:stylesheet version="3.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
  <!-- Identity template to copy everything as-is -->
  <xsl:template match="@*|node()">
    <xsl:copy>
      <xsl:apply-templates select="@*|node()"/>
    </xsl:copy>
  </xsl:template>
  <!-- Match the 'fileName' elements for 'job' elements with jobID 'B' -->
  <xsl:template match="job[jobID = 'B']/fileName">
    <xsl:copy>
      <xsl:apply-templates select="@*"/>
      <xsl:text>nieuw_something.pdf/</xsl:text>
    </xsl:copy>
  </xsl:template>
</xsl:stylesheet>
Output:
<?xml version="1.0"?><order>
<jobs>
<job>
	<jobID>A</jobID>
</job>
<job>
	<jobID>B</jobID>
	<fileName>nieuw_something.pdf/</fileName>
</job>
</jobs>
</order>
foxpalace
Post by foxpalace »
Hi, whitout npm install path und fs-extra no chance
tomgoertz
Post by tomgoertz »
Thanks for the quick feedback!
@foxpalace:
I actually already assumed that.
@sander:
Thanks for the idea with xslt. I just did some research and think I can solve my problem with xslt 1.0. It was a bit tricky to give the filename a prefix, since the original value also contains the complete path.
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
    <xsl:copy>
    </xsl:copy>
  </xsl:template>
  <!-- Match the 'fileName' elements -->
  <xsl:template match="fileName">
    <xsl:copy>
      <xsl:value-of select="concat(substring-before(., concat(../jobID, '\')), ../jobID, '\', ../jobID, '_', substring-after(., concat(../jobID, '\')))"/>
    </xsl:copy>
  </xsl:template>
</xsl:stylesheet>
sander
Post by sander »
Great :)
Just to be sure you know this: Switch XSLT transform only supports XSLT 1.0.
If you go with the Saxonica Saxon configurator you can use 2.0 and 3.0 too:
https://www.enfocus.com/en/appstore/pro ... nica-saxon
it is a bit of a "dirty" method, but the app "String Replace" can perhaps also do the trick if you define the substitution in the right way.
