A path with a variable in it
Posted: Mon Nov 13, 2023 12:58 pm
Is it possible to make a variable set with Pitstop Pro where I build a string with a fixed part and variable part?
For example /Volumes/Switch/Diecut/[diecutID].pdf
Where [diecutID] should be entered as a variable when starting the action?
To give you an idea what it should be for...
I'm creating a pit stop action where I overlay a diecut template on top of the pdf.
I'm using the PDF overlay tool built into pitstop to do this. I want to make the path to the overlay pdf variable.
I have tried all sorts of things but not seem to work.
Any ideas? Thanks!
Any ideas? Thanks!
