HTTP request (square brackets in JSON conflicts with Switch variables)
magnussandstrom
Post by magnussandstrom »
Hi, I'm bulding a flow where I want use the openAI API.
I'm using the latest version of HTTP request app (v19) and want to do the following:
Request type: POST a body
Body content: Custom > Multi-line text with variables
Where I would like to populate with the following JSON:
  "model": "gpt-4-1106-preview",
  "messages": [
      "role": "user",
      "content": "Write a poem about flowers"
  "temperature": 1,
  "max_tokens": 256,
  "top_p": 1,
  "frequency_penalty": 0,
  "presence_penalty": 0
...but since the JSON already contains [square brackets] I cannot use Switch variables to populate the JSON with my own data.
The only work-a-round I could figure out is to:
1. Create the JSON as a textfile (Create text file-app) but replace the square brackets with %startbracket% %endbracket%
2. Use String replace-app to convert %startbracket% %endbracket% to square brackets again
3. Post the textfile with HTTP request: POST > Attached file > [Job.Path]
But I guess that there is a better way, any suggestions?
Re: HTTP request (square brackets in JSON conflicts with Switch variables)
You can escape square brackets in switch variables by duplicating the opening brackets.
Can you try this?
  "messages": [[
      "role": "user",
  "temperature": 1,
  "max_tokens": 256,
  "top_p": 1,
magnussandstrom
Thanks Padawan! I did not know about that escaping method, the escaping works but I stumbled on another issue.
I get a 400 response (Bad request) when using the latest HTTP request v19 app. I tried both 'POST a body' and POST with file > [Job.Path]
When I roll back to the older HTTP request v15 and use POST with file > [Job.Path], it works fine and I get the expected response.
I have trippled checked that I'm using the same settings, but some how I can't get the HTTP request v19 to work..
Any suggestions?
Are you using custom headers?
magnussandstrom
Yes, the Headers property in the app are set to Multi-line text with variables and are populated with:
Content-Type: application/json
Authorization: Bearer ********
I can see that they seem to be handled correctly in Messages/Debug:
There was a problem with application/octet-stream always being added in case of a POST, thus overwriting the custom header value. There will be a beta version of HTTP request v20 next Tuesday. If you are on the list of beta users you will receive a notification of that. If not, send me a mail and I will add you. I will be looking forward to your feedback.
magnussandstrom
Thanks Freddy, I’ll send you an email.
