Anyone having connection issues with Griffin Auto?
Posted: Tue Nov 21, 2023 11:17 am
by jasonx
Receiving ID Error (1): -211 when trying to start.
Re: Anyone having connection issues with Griffin Auto?
Posted: Tue Nov 21, 2023 3:41 pm
by magnussandstrom
We have also problems with Griffin auto today, I don't know if it's related to yours. I have contacted my supplier and submitted an Enfocus support case.
Posted: Tue Nov 21, 2023 7:38 pm
by jasonx
It seems the issue was related to licensing.
I was starting Griffin Auto from command line to see the error.
I did message you on Instagram directly to ask you :)
If you like we could share email incase something like this occurs in the future?
Posted: Tue Nov 21, 2023 7:58 pm
by magnussandstrom
I got a response from Enfocus/Esko that the issue is fixed now. It's working on our end again.
I'll take a look on Instagram :)
Posted: Thu Nov 23, 2023 9:49 am
by Egon
Same problem yesterday and Enfocus indeed solved the problem! Doesn't change the fact that I Griffin still only works with a VPN connection with us!
Posted: Thu Nov 23, 2023 10:09 am
by magnussandstrom
Egon wrote: Thu Nov 23, 2023 9:49 am Same problem yesterday and Enfocus indeed solved the problem! Doesn't change the fact that I Griffin still only works with a VPN connection with us!
I'm not sure why need to use VPN? But yeah, it's a strange licensing model. IMHO on premise software should function even if there is a lost of internet connection for a day. That could happen for many reasons.
Posted: Thu Nov 23, 2023 10:14 am
by Egon
magnussandstrom wrote: Thu Nov 23, 2023 10:09 am
Not sure what our problem is, but Griffin only works with a VPN connection for us. Most likely it is something internal, but we have already tried everything, even switching firewalls! Maybe I will create a separate topic for our problem, maybe Enfocus will realize the seriousness of our problem a little more after the takeover of Griffin!
Posted: Thu Nov 23, 2023 2:07 pm
by Robert.W
We had also the license issue, for the third time.
This is annoying. Griffin has a license key with subscription.
There should be a fallback option so that Griffin continues to function for at least 48 hours.
Posted: Thu Nov 23, 2023 2:54 pm
by magnussandstrom
Robert.W wrote: Thu Nov 23, 2023 2:07 pm There should be a fallback option so that Griffin continues to function for at least 48 hours.
This!
Posted: Thu Dec 28, 2023 10:14 am
by jasonx
Hopefully they change how it works moving foward.
Posted: Mon Mar 11, 2024 10:20 am
by Robert.W
And again there is a license issue.
Is anyone else affected?
Posted: Mon Mar 11, 2024 9:24 pm
by magnussandstrom
We have not noticed any issues with the Griffin license lately.
Posted: Tue Aug 27, 2024 2:21 am
by joaodaffonsojr
Hello !
I tried using Griffin Auto with Switch today but it's not working. I get the following message in the Switch Log:
Process failure due to unexpected internal error. If problem persists please contact support to resolve.
Could not connect to bundled application
Could not start service during GET
App initialization failed
Still initializing Griffin app, please make sure internet is accessible
When I tried via cmd line:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.codehaus.groovy.reflection.CachedClass$3$1 (file:/C:/Program%20Files/Tilia%20Labs/Griffin%20Auto/groovy-all-1.8.5.jar) to method java.lang.Object.finalize()
WARNING: Please consider reporting this to the maintainers of org.codehaus.groovy.reflection.CachedClass$3$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
ID Error (1): -211
Any Suggestions ?
Posted: Fri Oct 11, 2024 9:18 am
by Robert.W
For Griffin problems I always look at the rolling.log:
C:\Users\Username\AppData\Roaming\Enfocus\Switch Server\ScriptData\com.tilia.griffin.app\log
Maybe there is more information about your error. Enfocus support can also reset the license.
