I have multiple job assemblers in my flow, that use the same metadata of the job. I have job identifier and number of files specified, no complete condition.
In the first stage, the assembler sometimes assembles a job when it has fewer files than required (Metadata says 9, but job is assembled from 8 files) and processes it without errors like a regular job. Now when this job reaches the other assembler, it is finally sent to the error connection, because not enough files exist to assemble it.
One thing to note here, is the reason why one file is missing. Sometimes the file has duplicate information for creating a pdf, which means Switch creates the same PDF twice, overwriting the first one. Could this be the reason Switch thinks that a 8 file job is good to assemble? Although the question still remains, why two assemblers act differently.
Job assembler acting different in same flow
- magnussandstrom
Re: Job assembler acting different in same flow
Have you double checked that the metadata in all the incoming files says 9?
Yes, the metadata is created in one xml file, that is then attached to all the files created by the job.magnussandstrom wrote: ↑Thu Dec 21, 2023 1:14 pmHave you double checked that the metadata in all the incoming files says 9?
- magnussandstrom
Strange, I have not stumble on this issue and I use Assemble job in similar way as you descripa in several flows. I have noticed some strange behavour during testing when you stop or hold flow connections when using Assemble job, so now I always delete any jobs still in the flows when restarting a flow if Assemble job is used.
