Varnish size reduce and remap
ballonagnes
Post by ballonagnes »
I have a PDF which has a White ink varnish page.
1. I need it to reduce completely with value -0.2mm, it's also could calling as trapping..
2. White ink to WHITE_INK remapping
On the page you can find vector and picture too. I found here from another topic a clipping mask.eal action list, there were asked placing a rectangle on the Varnish layer... viewtopic.php?t=4839
Could anybody help me about this? Is there any option to solve with pitstop pro?
Sorry the file is big, I could send it through per wetransfer.
https://we.tl/t-XYwPLYeUb6
thanks,
Agnes
Re: Varnish size reduce and remap
If you want to "contract" the varnish object, you could use the "Offset path"
Unless I got you wrong.
ballonagnes
Hi, thanks! I think it could be the solution.
