Save embedded preflight profile from Certified PDF
Posted: Fri Feb 09, 2024 11:19 pm
I've received a Certified PDF. It names the profile that was used to certify it. I can recertify it, by checking the PDF against the profile in the certificate again.
Can I save the profile from the certificate as a preflight profile (or even as text)? Or somehow view the settings and actions?
I know I can remove the certification. I don't want it removed. I'd like to see what the profile is checking/doing. (The profile makes modifications to the PDF, so when I recertify it makes those changes again.)
My issue is I have received a Pitstop preflight profile from a print vendor that I was instructed to run against any files submitted. They've told me there is an issue with one of my files. The file they returned is a certified PDF, with a different profile used. (It failed against that profile.) I would like to compare the two profiles.
