Bypass 'Hold job' with time window?
blingen
Post by blingen »
Is it possible to cleanly bypass a 'Hold job' element using a time window without messing up file names and Switch prefixes?
We need to do this every so often for escalated priorities or to get things back on track if issues occurred.
We've run into issues copying files from the folder before the hold and pasting them in the folder after it because the Switch prefix becomes part of the filename going forward. This means a lot of our later programming that depends on the filename is broken.
rhd_ole
Re: Bypass 'Hold job' with time window?
Post by rhd_ole »
blingen wrote: Fri Mar 15, 2024 5:11 pm Is it possible to cleanly bypass a 'Hold job' element using a time window without messing up file names and Switch prefixes?
Whenever you manually copy a file and place into a folder the unique prefix will always be part of the name, I don't think there is away around it. We have done something similar where branch from the folder to another which will copy all jobs, then the connection between that folder and the folder after the hold, delete all the files we don't need to rush and then let that one pass though. Kind of clunky but it's a rarity for us so it's worked well.
