Illustrator script arguments and variables
wwstudios
Post by wwstudios »
Hi all,
currently working with a demo version of Switch with Illustrator.
desired workflow is to run a variable data script we use. so it would go like this:
1. open file
2. run script (fill in arguments below)
a. choose specific radio button for layer name or object name. Variable is 'r_textByName', which will be true
b. choose csv file to use (should be in the same input folder with the same 5-digit job number). variable is 'disp_csvFile'
c. define output directory. variable is 'disp_destFolder'
3. The script should then run and save pdfs (Settings defined in script) to the output directory
But what is my syntax for this?
In argument 1, I just put the following inline:
r_textByName.value = true;
Then in argument 2, for choosing the correct csv file, I'm really stumped. I need to match the csv to the Illustrator file, and I assume the easiest way is to use a variable for the file path, but how do I match it on the fly, with different 5-digit job numbers?
Finally, for argument 3, the output directory, I have this:
var disp_destFolder = [Switch.OutgoingName:Index="1"] (I had 'OUTPUT' and 'OUTPUT BAD', so I used the Index to limit it to the first one.)
obviously this isn't working at all, since I don't have argument 2 figured out in the least.
Is there a good reference for dealing with Illustrator script arguments?
Or even if there's a better method of doing variable data with Illustrator and Switch?
thanks for any help
Re: Illustrator script arguments and variables
You should start from here: https://www.enfocus.com/manuals/UserGui ... tions.html. There you will find what variables Switch makes available to your script and how it works with arguments.
wwstudios
Post by wwstudios »
Awesome, thanks much!
