Reduce bleed
Reduce bleed
Is there an easy and safe way of reducing bleed on a page. For example the file has been supplied with 25 mm of bleed and needs to be reduced to 5mm
Re: Reduce bleed
You can use this action:
In short:
In short:
- Extend trim temporarly to have bleedbox dimensions
- Clip bleed around contour using trim as contour/list]
- Contract trim to its initial size
Re: Reduce bleed
Cool
Just tried it, works well
