Select variable range of pages
Posted: Thu Apr 18, 2024 5:27 pm
by JimmyHartington
I am a bit stumped with an action list I am trying to make.
Maybe I am missing something obvious.
I use a tool to create a table of contents based on bookmarks in a pdf.
It is added as the first pages of the pdf.
It could be 1, 2, 3 etc number of pages. It is determined automatically by the program.
Afterwards I would like to process the pdf with Pitstop.
On the pages with the TOC I will need add graphics at the top and set page labels.
On all the other pages I need to add pagenumber and set another version of page labels.
The TOC is set with Courier-Bold. Which should not be used anywhere else in the pdf.
I tried to
select page range 1-10
select font by name Courier-Bold
AND
Add copied graphics.
But that did not work.
What am I missing?
Re: Select variable range of pages
Posted: Thu Apr 18, 2024 7:05 pm
by loicaigon
Hi Jimmy,
I think you problem comes with the mistype of selection.
When you do:
AND
You try to combine two different kind of objects: a page AND a font so it doesn't work.
Here is what you can do:
You may want to…
select objects if page is selected
AND
select page if content is selected
Add copied graphics
In short:
- Find font among selected objects
- Get pages where those object reside
HTH
Posted: Thu Apr 18, 2024 9:50 pm
by JimmyHartington
Ahh. It was something I missed.
Of course I can not add graphics when I end up not having at page selected.
I will try this.
Posted: Thu Apr 18, 2024 10:52 pm
by JimmyHartington
Hi Loic
That work with selecting the pages with the TOC.
Now I have trouble selecting all pages EXCEPT the TOC.
I probably need to place a NOT the correct place.
Now I have:
Select all pages
Select objects if page is selected
Select font Courier-Bold
NOT
Select page if content is selected
- Do changes -
But it seems to select all the pages.
Posted: Fri Apr 19, 2024 9:56 am
by JimmyHartington
I have ended up splitting it into 2 actions lists.
In the first Action List I fix the TOC.
I also set page labels on the TOC pages.
In the other action, my selection is then
Select All Pages
Select Pages with Page Label (to select the TOC pages)
NOT
- Do changes -
And since this process is running in Switch I just add the 2 action lists in the configurator.
Posted: Fri Apr 19, 2024 10:23 am
by loicaigon
Hi Jimmy,
I think you need to AND all pages and NOT pages with page label
- select pages with page label
The AND is necessary because NOT will select "everything" but the pages with page labels (including Document and objects).
So AND makes sure that you still refer to the all pages selection and that you only process pages eventually.
HTH
Posted: Fri Apr 19, 2024 10:37 am
by JimmyHartington
loicaigon wrote: ↑Fri Apr 19, 2024 10:23 am
It works with just the NOT.
Maybe because both actions are selecting pages?
Posted: Fri Apr 19, 2024 11:28 am
by loicaigon
Oh my bad then.
NOT is a bit tricky because it selects everything but the selection concerned by the NOT.
I believed it would explain your issues.
