Error in Node.js Scripting within Switch
gregbowers
Post by gregbowers »
Hello
I'm facing an issue while working with Node.js scripting in Switch. When trying to execute a script, I am getting a 'Module not found' error for a dependency, even though it's installed correctly using npm. I've rechecked the paths and verified that the module is listed in the package.json file.
Has anyone else faced this issue before, and if so, how did you resolve it? Any help would be greatly appreciated.
Thank you for your assistance!
Thank you
gregbowers
memberlist.php?mode=viewprofile&u=4437info
plutinolabs
Re: Error in Node.js Scripting within Switch
Post by plutinolabs »
Hi gregbowers
I've been going through that last couple of weeks. In my case, I found downgrading modules worked for me.
I think some of the newer modules are incompatible with the node runtime that's installed with switch?
tdeschampsBluewest
Post by tdeschampsBluewest »
There is a similar issue for nodeFetch and some release of axios, downgrading your package can (sometime) fix the issue as stated earlyer
Example of installation : npm i axios@0.27.2
foxpalace
Post by foxpalace »
normal is that not - I use node-exiftool ... in a older Script Version 2.3.0 is working - now i create a script, npm i node-exiftool ... not working - same version 2.3.0
Error: Failed to transpile the code: TypeScript failed with exit code 2
Error: TypeScript standard output: main.ts(1,27): error TS7016: Could not find a declaration file for module 'node-exiftool'. '/Users/Shared/nodejs/dev/insertXMP/node_modules/node-exiftool/src/index.js' implicitly has an 'any' type.
Who should unterstand that - exactly same version
foxpalace
Post by foxpalace »
Hi, in my old Script I worked whit import - now it worked whit require:
const exiftool = require('node-exiftool');
If someone have the same Problem - try require.
