hotfolder
Posted: Mon May 27, 2024 10:22 pm
by DiegoAsterBR
Could someone clear my doubts, I'm trying to make a hotfolder using the pitstop server, I created an entry with the name "input" and another with "output" I made all the settings according to the videos that the searches, I did all the email configuration as well and everything went well with the email test, but when I put it in the PDF in the input folder nothing happens, it doesn't activate the preflight that I generated which is a 3mm bleed.
Re: hotfolder
Posted: Tue May 28, 2024 3:54 pm
by sander
It looks like your hot folder is disabled. When enabled it should show a white V. Right click the hot folder and enable it.
Check attached screenshots!
Re: hotfolder
Posted: Fri May 31, 2024 2:12 pm
by DiegoAsterBR
It worked, thank you very much, that was the detail, everything is working fine, just one question, when I create a folder many sub-folders appear, is there an option where only the folders that I created appear, which are input, output and error
Re: hotfolder
Posted: Fri May 31, 2024 3:14 pm
by sander
Some folders are mandatory. These are configured at your setup, see screenshot in your first post.
When configuring a HotFolder it'll show the mandatory 'errors' in the lower left corner, see screenshot.
