Where is Flow Stage metadata stored?
KingSwitcher
Post by KingSwitcher »
I'm trying to find where flow stage is stored within a job's metadata. Any direction?
I'm using Refresh Job Info to set various stages but can't find a way to pull it from a job downstream.
Re: Where is Flow Stage metadata stored?
Right click on it in the app list and select "app details..."
https://www.enfocus.com/en/appstore/pro ... h-job-info
KingSwitcher
jan_suhr wrote: Tue May 28, 2024 10:21 pm Right click on it in the app list and select "app details..."
I've already looked through the documentation. Including "Working with Job Info" in the switch reference guide.
Unless I'm just missing it, I can't find any mention of accessing Job Stage anywhere outside of the Switch Portal.
As you see in the documentation I linked to the app Refresh Job Info is intended for the Switch portal and to show infor fr jobs in that interface. There is no metadata that can be picked up.
What you are looking for can be done with Private data that you can add when a job passes a folder.
