Hi! Is it possible to crop the page to cut the transparent part of the image using the Action list?
There is a nice Action list called "Crop to visible", but this option cuts the White color also.
Maybe it is possible to cut just the outer part without any color?
https://drive.google.com/file/d/1B2qTEJ ... sp=sharing
Crop to Visible including WHITE
Re: Crop to Visible including WHITE
You should get the expected result selecting all and changing page boxes based on the active selection.
Note however that you may want to ensure that page boxes are properly defined first and that you actually select the page content.
Select all, actually selects objects but also the pages, and the document.
Enfocus PitStop Manager
Changing page boxes based on the active selection is not working, because selected objects include also some transparent parts, which I must cut off.
Maybe you want to share a sample file?
- JimmyHartington
I do not know how precise it needs to be.
But you could experiment with using the "Add Trace Path" and then set the Media Box according to this path.
And then delete the path.
Action list:
Result:
Action list:
Result:
I am assuming that there would be multiple pages that are different sizes/shapes that need to be cropped to? If not you could just resize the crop box to the size that you wanted or make a mask. If the size of the images change that is much more difficult.
