Switch v PitStop
AndrewLane
Switch v PitStop
Post by AndrewLane »
Hello all,
I'm hoping someone can help me. I need to get the color Management in Switch to match with our PitStop config. The problem is that I have ICC profiles available in PitStop that aren't available in Switch.
This is PitStop Pro and Switch both installed on the same machine. If I search for *.icc files i still can't find the profiles I need. Namely:
FujiFilm Generic Gray3.icc
FFEI Input Lab Profile
I'm not currently in a position to change the profiles used in PitStop so need to get Switch using the same options.
Any suggestions as to how I can find those profiles?
Thanks in advance
Re: Switch v PitStop
Those are default profiles installed with PitStop. You can find them in the PitStop Pro installation folder, but the file names are different: Generic Enfocus Gray.icm and Generic Enfocus Lab.icm.
The internal name of these is FujiFilm Generic Gray3.icc resp. FFEI Input Lab Profile, but the file name doesn't match the internal name.
AndrewLane
Thank you
