Find text close to 3 mm or less from Trimbox
NEOSA
Post by NEOSA »
Hi All,
I tried to setup a flow using PitStop Server, but the main goal is to find and log if some Text is close from 3 mm or less relative to the Trimbox.
I did an Action to log if conditions are reached by doing this :
- Remove ArtBox
- Change ArtBox size from TrimBox
- Resize ArtBox size with -3 mm offset
- Select All
- Select Text Segment
- Select objects outside ArtBox
- AND
- Log as error if objects are selected
...but no selection is done :-(
Do you have such Actions for doing this ? Or any others solutions ?
Thanks a lot for help ;-)
Re: Find text close to 3 mm or less from Trimbox
Have you tried the action "Select objects close to the page edge" or "Check if object is close to the page edge"?
NEOSA
Post by NEOSA »
bens wrote: Wed Jun 05, 2024 10:19 am Hi,
Thanks bens !
The setup does the job ;-)
