Split PDF into indivudal pages based on closed spot color selection
jasonx
Post by jasonx »
If I have a PDF with two closed shapes one is a circle and one is a square with a stroke color named spot. I am trying to save an individual pdf with the circle and one with the square.
Is there a way I can cycle through the selection of objects? I also have switch?
Or is there a more elegant way of doing this?
Re: Split PDF into indivudal pages based on closed spot color selection
Look at those Actions:
- Copy or cut objects to clipboard
- Add pages
- Select pages
- Paste objects from clipboard
Another option is to put the square on its own layer and use this Switch app:
https://www.enfocus.com/en/appstore/pro ... pdf-layers
