Trying to remove underscore at the end of a filename.
MichaelG
Post by MichaelG »
I am trying to remove an underscore "_" from the end of a filename using the Rename Job flow element and I'm not having any luck. It should be easy, but I'm stuck.
sander
Re: Trying to remove underscore at the end of a filename.
Post by sander »
This will do:
1. _.[Job.Extension]
2. .[Job.Extension]
MichaelG
Post by MichaelG »
Yep, that worked. Thank You.
tdeschampsBluewest
Post by tdeschampsBluewest »
You should also make it recursive, to remove multiple underscore at the end, just in case :).
