Pitstop Server skipping pages on XML Report?
Soul Forge
Post by Soul Forge »
So, I've built this flow for one of my clients that takes many information generated by Pitstop Server checks, then it sends e-mails with the treated information.
But they noticed that some pages were missing in the reports my flow sent.
After performing multiple tests I've noticed that some pages are missing in the Ink Info report. What could be the cause of it?
Re: Pitstop Server skipping pages on XML Report?
Can you address this to support?
Loic
Soul Forge
loicaigon wrote: Mon Jul 08, 2024 5:10 pm Hi,
Loic
E-mail sent!
Thank you.
JimmyHartington
Post by JimmyHartington »
I just got to ask the simple question.
Could it be blank pages?
If yes, I would of course still have them reported in the XML with zero as value.
tdeschampsBluewest
Post by tdeschampsBluewest »
Could it be the label of the page in the report instead of the page number?
Do you have a missing ones in your label names?
Soul Forge
JimmyHartington wrote: Tue Jul 09, 2024 7:27 am I just got to ask the simple question.
Unfortunately it's not. Nevertheless even if it was it should report 0 ink usage, as it could be useful for decision making.
tdeschampsBluewest wrote: Tue Jul 09, 2024 9:10 am Could it be the label of the page in the report instead of the page number?
I actually don't know what you mean by page label.
The page number 56 actually has 80 something percent of black ink usage. The flow should report just that, when a page uses ink above a certain percentage.
Using pitstop pro, the pdf report is working fine.
JimmyHartington
Not to say anything isn’t wrong with Pitstop Server.
But if you are running it through Switch, what have you set as the limit in the configurator?
Soul Forge
JimmyHartington wrote: Wed Jul 10, 2024 7:54 am Not to say anything isn’t wrong with Pitstop Server.
Well, the default number is 100, but when I looked at it before I created this post it was 1000. Then, also before I posted, I tried changing it to 50.000.
Nothing worked.
Even if it was a problem with this limit, I guess the intended behaviour would be to truncate the last lines, not some in the middle, right?
JimmyHartington
Soul Forge wrote: Wed Jul 10, 2024 11:07 am Even if it was a problem with this limit, I guess the intended behaviour would be to truncate the last lines, not some in the middle, right?
You are right. It should truncate from the end.
I think you have now exclude the obvious possiblities for user error.
So lets here what Loïc and the support finds out.
tdeschampsBluewest
[/quote]
[/quote]
Page number can differ from page label.
The index, is the position as an integer, the label is a string,
In most case, page label = page index, but in some case if you added label to your pages, and remove some pages, the labels can mismatch the index.
Soul Forge
tdeschampsBluewest wrote: Thu Jul 11, 2024 5:17 pm In most case, page label = page index, but in some case if you added label to your pages, and remove some pages, the labels can mismatch the index.
Oh! I've seen a couple files with this problem before, some even using roman numerals, for whatever reason.
Unfortunately it's not the case for this file.
Hi all,
We identified a bug in the XML V3 report that doesn't translate information as it should. First, it's important to understand that in the PDF report, pages having a same amount of Ink coverage get gathered ( Page 2, 6, 15…). Here the xml report applies the same logic but doesn't report properly.
This is logged and will be fixed. The workaround right now is to choose XML v2 reports.
Loic
Soul Forge
loicaigon wrote: Fri Jul 26, 2024 8:49 am Hi all,
Loic
Thanks for the workaround, I'll apply it in the flow!
