Place rotated text
Posted: Thu Jul 11, 2024 9:35 pm
by wkopp
Hello all,
I'm trying to place some text on a pdf that runs vertical. I don't see anything in the Add Object settings that will let me do that. Am I missing something? Seems like a simple thing but I can't find the control.
Thanks in advance for your help!
Re: Place rotated text
Posted: Fri Jul 12, 2024 8:03 am
by JimmyHartington
After placing the text, you can use the action "Select last added object".
Then use "Rotate object".
Posted: Fri Jul 12, 2024 9:08 am
by tdeschampsBluewest
Sometimes rotating an object with good positioning could be painful, so alternatively, you could rotate your page, position your text, then rotate-back your page.
Posted: Fri Jul 12, 2024 9:34 am
by JimmyHartington
tdeschampsBluewest wrote: Fri Jul 12, 2024 9:08 am Sometimes rotating an object with good positioning could be painful, so alternatively, you could rotate your page, position your text, then rotate-back your page.
That is a great idea.
I have sometimes used Art Boxes as targets for different placement of graphics.
So in this case an Art Box could be set to where the text should be used.
Add text.
Rotate text.
Align text to Art Box.
Remove Art Box.
Posted: Fri Jul 12, 2024 5:57 pm
by wkopp
Thanks to both of you. I thought there was a Select Last Object but couldn't locate it. Got it now and working well for what I need. Thanks Jimmy! Also thanks to Bluewest. That sounds like a great idea for more complicated projects.
Appreciate you both!
Posted: Fri Jul 12, 2024 6:03 pm
by loicaigon
You mean "Select Last added objects"?
Posted: Fri Jul 12, 2024 6:11 pm
by wkopp
Yep, got it. Didn't type out the whole name, but got it. :) Thanks!
