How can I capture the text result of grep into Private data?
Working terminal code which gives a text file with the grep match:
pdfgrep  -P 'T\d+' TEST.pdf | tee output.txtCode: Select all
pdfgrep  -P 'T\d+' '%1' > '%2\[Job.NameProper].txt''Output' Updated input job (also tried to see a text file alongside with 'result next to input')
'Exit code' Discard
'Stdout' Attach as dataset
'Stderr' Discard
Disregard exit codes
My bash knowledge is poor and the syntax required for 'Execute command' is occult to me as well! Thanks so much for reading.
