CSV => line by line API calls
w.bromley
Post by w.bromley »
Hi Guys!
I have a use case whereby I need to take a supplied CSV and make an API call based on each line.
I guess I need to either load in each line as either attached XML or private data and then use that to populate my API call...
I am struggling with the first part of this...
A suggestion I has was:
-Use Saxon with an XSLT to transform your CSV file into an XML file
-Use Saxon with a second XSLT to split your new XML file into each listing in your original CSV.
-Pick up each XML as its own Switch dataset/job
-Construct your API call from the necessary elements in the attached XML
I am struggling with this - as I cannot work out how XSLT would work in this context (I am very new to XSLT!).
Any help or suggestions or examples would be much appreciated...
Thanks in advance!
Re: CSV => line by line API calls
There is an app for that.
CSV2XML will fix it for you.
w.bromley
Post by w.bromley »
Ahhh excellent - I will give that a try!!!
Cant get Saxonica working at all - got a simple demo csv and xsl and it's just erroring every time... :(
JimmyHartington
Post by JimmyHartington »
My Switch is running on Windows.
Here I use a command line program to split a csv to single lines (https://download.cnet.com/csv-splitter/ ... 10188.html).
And Easy Data Transform (https://www.easydatatransform.com) running as commandline to convert to XML.
Then XML Pickup to get the data to work with in Switch
Let me know if you need a more details about how I do it.
magnussandstrom
Post by magnussandstrom »
w.bromley wrote: Mon Aug 12, 2024 5:18 pm Ahhh excellent - I will give that a try!!!
Could you please upload the demo csv? I'm curious to see if I can get it working in Saxonica.
w.bromley
Post by w.bromley »
Speaking to support it seems like Saxonica often causes issues - they have recommended I try it via the CLI rather than use the actual element!
magnussandstrom
Could you share the demo CSV?
w.bromley
Post by w.bromley »
I cant seem to attach - invalid format - I will paste below!
CSV:
Name,Age,Location
Alice,30,New York
Bob,25,San Francisco
Charlie,35,Los Angeles
XSL:
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<!-- Root element of the output XML -->
<xsl:output method="xml" indent="yes"/>
<!-- Template for the root of the CSV XML -->
<xsl:template match="/csv">
<root>
<xsl:apply-templates select="row"/>
</root>
</xsl:template>
<!-- Template for each row in the CSV -->
<xsl:template match="row">
<record>
<xsl:for-each select="cell">
<xsl:element name="field{position()}">
<xsl:value-of select="."/>
</xsl:element>
</xsl:for-each>
</record>
</xsl:template>
</xsl:stylesheet>
magnussandstrom
It was indeed hard to convert from CSV to XML with Saxonica.
I would use this approach instead (if not Jan or Jimmys suggestions suites you better):
1. Convert CSV to XML with Easy data transform (app coming soon)
2. Split the XML with Saxonica
3. XML pickup
w.bromley
Post by w.bromley »
Jan's suggestion was perfect - I have the workflow basically build and already thinking of ways to roll it out to other use cases!!!
Thanks everyone for your help :)
