Hi All,
I curious if it's possible to pass a swtich variable as you normally would in javascript but use in a database query within the script.
For example, Privatedata of "job_number"
And then pass that into the query within the javascript.. So far I haven't been able to do that. I'm using to to pull more info about the job from our MIS based on the job number.
Script in Checkpoint
thelmaolmos
Re: Script in Checkpoint
Yes, it is possible, but how you do it depends entirely on where your JavaScript is running. The key rule is:
- JavaScript in the browser cannot talk directly to a database.
- JavaScript on the server (Node.js) can.
