Find and Replace font issues, also automation
cwswitch
Post by cwswitch »
Attached is: https://drive.google.com/file/d/1FhM-uk ... sp=sharing
  • a PDF with "XXXXXX" in a spot colour
  • a working action
  • a broken action
In the broken action, I do not use "replace font" and the result has broken kerning.
In the working action, I do use "replace font" and the result is good.
My goal is to use the action in Switch but I do not really want to build an action per font.
Switch can give me the font name, but it does not look like the action can take a variable for this.
1) is there a way to pass in a varible here?
2) is there another way to achieve this?
Thank you for looking!
magnussandstrom
Re: Find and Replace font issues, also automation
Post by magnussandstrom »
This was a tricky one, I did not find a solution. I even tried Convert to postscript > PDF > Run action (without any luck).
Last edited by magnussandstrom on Wed Sep 11, 2024 8:12 am, edited 1 time in total.
cwswitch
Post by cwswitch »
Interesting one hey Magnus!
The "change font" step seems essential but cannot be driven by variables so I cannot automate for all documents
tdeschampsBluewest
Post by tdeschampsBluewest »
Hi there,
I think it's tied to corrupted font width, I gave a try to "Change corrupt font widths" in place of your "Change font", and it worked fine (at least for me!)
cwswitch
Post by cwswitch »
Awesome! thanks!
I had to also add in "Select corrupt font widths" (Tolerance 0) before the "Change corrupt font widths"
Looks to be working :D
