Filename with file size
Prepress1
Post by Prepress1 »
Hello.
Is it possible to extract file size info(trimbox or mediabox) in mm and add the info to processed files filename in pitstop server?
Thanks in advance.
Prepress1
Re: Filename with file size
Post by Prepress1 »
something like this:
laurentd
Post by laurentd »
This is not possible with PitStop Server, because these variables are not available in PitStop Server.
But you can easily do this (and a lot more) with Enfocus Switch.
And, good news, if you don't have Switch yet, you can install it on the same computer as PitStop Server.
Switch will find PitStop Server's license (from 2020), and run as "Switch Core Engine", the basic module without extra modules.
(It is possible to add more modules later on to add more features to Switch)
Here is a sample flow to rename the files as asked. Just double click to import in Switch.
Rename pdf with trimbox size in mm.sflow.zip
(14.65 KiB) Downloaded 968 times
And here you can download Switch 2024 Spring installers: Windows - Mac ARM - Mac Intel
