As part of my effort to organize the internal workflow I would like to prepare a printable (pdf) job ticket which includes all the metadata (external and internal).
I may be totally wrong but the only way I found (and I am new to the environment) is to export metadata convert it to csv (xslt) and to merge it with an VDP template (let's say Designer).
I have all the modules but before getting to code it I would like to know whether there is a easier way.
Thank you
Ariel
A printed job ticket
- TOP CONTRIBUTOR
I've implemented many simple and complex job tickets for my customers using Apago PDF Constructor. A Switch script creates an XML description of job ticket layout including text, barcodes, images, PDF pages, form fields, etc which PDF Constructor converts to PDF.
ArielRauch
sounds very interesting!
Unfortunately, we have already installed Indesign Server and DEsigner Server which as far as I understand - are covering more or less the same functionality.
- TOP CONTRIBUTOR
Here's an example of a job ticket we created for a customer.
ArielRauch
very impressive!!!
ArielRauch
there are no technical data on your ticket. What is the best way to extract size, color space, bleed and so on from the pdf file to a csv or at least to xml?
- TOP CONTRIBUTOR
Use Switch's Statistics variables or for more detailed information use Apago PDFspy.
- TOP CONTRIBUTOR
Another job ticket created by PDF Constructor in Switch flow
