new handling of eason: The flow element instance has no outgoing connections of the specified level that carry jobs of t
Posted: Mon Oct 14, 2024 9:10 am
by borisCM
i updated my switch installation to the 2024 spring version.
but now i get errors when a script element does not have a output connection with that level.
before it was just a warning.
anyone else had that issue?
I used it a lot to just force a send to null in the flow, but now i need to add the connection and place a bin there.
Can i check the connections in the flow and see if it the connection is there and if not send the job to null?
"... to the problem jobs folder. Reason: The flow element instance has no outgoing connections of the specified level that carry jobs of type Data"
kind regards
Boris
