Inject Wildcard error
PdFUser5000
Post by PdFUser5000 »
The following error occurs randomly, few times a day. Could this be connected to the job being saved by the user at the same time switch tries to copy it?
Creating job error: Cannot upload job, provided path does not exist Error: Creating job error: Cannot upload job, provided path does not exist at _0x4179ea._createJob (C:\Program Files\Enfocus\Enfocus Switch\ScriptExecutor\nodemodules\node_modules\switch-scripting\index.js:2063:27)
sander
Re: Inject Wildcard error
Post by sander »
I’ve encountered this exact same error with the HTTP request module. Initially, it appeared to occur randomly, but later I found that I could more or less trigger the error under heavy load.
It took a while to debug but I got this response:
"Apologies for the long delay, but I was told by the developers that they have fixed this issue in the upcoming release of Switch 2024 Fall."
That being said, this doesn’t appear to be an App issue, but rather a Switch issue :(
Case number: ENF-00212295
