Adding Blanks to Odd Page Counts
MichaelG
Post by MichaelG »
I'm trying to find a way to detect an odd page count, and then add a blank page so that every job sent through the Flow has an even page count.
I can do it with a Pitstop Server Preflight, but it gets time-consuming especially when we're doing this to 5,000 jobs.
Any ideas?
tdeschampsBluewest
Re: Adding Blanks to Odd Page Counts
Post by tdeschampsBluewest »
You can detect the odd number of page by doing a check in an arrow connection, it will avoid opening pitstop for unecessary document.
[Switch.Calculation:Expression="[Stats.NumberOfPages]%2"]
If equal to 0, it's an even number, otherwise it will be 1, so an odd number.
MichaelG
Post by MichaelG »
Yes, That worked. Thank you.
r.zegwaard
Post by r.zegwaard »
I think there is an easier solution.
Set the action "Add pages" to add "Until a multiple of 2"
I think our friend wanted to avoid running PS if not necessary. I.e. if the number of pages is already even.
Thomas' answer in that regard is indeed the best way to go. Fastlane could as well be used with mimimal performance impact.
But in that case, the condition with metadata simply makes sense.
