Same Pg Number on multiple pages
Posted: Thu Jan 09, 2025 5:25 pm
by rhd_ole
Hi All -
Once upon a time I feel like I was able to do this, but I can't figure out how I did it. I didn't backup my flow.
I'm looking to put the same number on multiple pages.
Eg: multiple page pdf
  • pg 1-4 = should all have 1 on them
  • pg 5-8 = should all have 2 on them
  • pg 9-12 = should all have 4 3 on them
and so on....
What's the best way?
Re: Same Pg Number on multiple pages
Posted: Thu Jan 09, 2025 7:16 pm
by loicaigon
Hey there,
If you use Select pages, there is an option for "Select every Nth page". There you can set every 4 pages from 1 to (leave empty).
Then add page number.
Repeat operation for pages from 2 to
Repeat operation for pages from 3 to
Repeat operation for pages from 4 to
That should do the trick.
Posted: Thu Jan 09, 2025 7:59 pm
by rhd_ole
That is it!! Thanks!
If I were want to add in a data matrix barcode how would that work? When I tried using the similar action but it uses the actual number in the PDF, so the 2nd group of 4 pages(page 5) has metrix of 5 instead of 2.
Thoughts?
Posted: Thu Jan 09, 2025 8:26 pm
by loicaigon
There might be a way but how many total pages could you expect to have?
Posted: Thu Jan 09, 2025 8:39 pm
by rhd_ole
There will like 14k pages, every 4 pages is a new 'record'
I guess now production would like the same 2d data matrix on page 1 & 3 of 4 pages keeping going up by 1 every 4th if that makes sense.
I did remember what I did last time with a 3 page but we ended up splitting the file into groups of 3, then as singles. I wrote a script to sort each split so they could be assembled. All page 1 of the 3pages were merged, then page 2 of the 3 and so on. then we added the matrix code to the which ones we wanted and the numbering would the same since they were all the 'same' pages were assembled as one pdf. After that I put them back to be imposed. Super cumbersome but it worked I guess.
Posted: Fri Jan 10, 2025 5:55 pm
by loicaigon
The workaround I was thinking of won't work for 14k pages. I guess some split/merge with Switch may indeed be the way to go.
Posted: Fri Jan 10, 2025 6:12 pm
by rhd_ole
loicaigon wrote: Fri Jan 10, 2025 5:55 pm The workaround I was thinking of won't work for 14k pages. I guess some split/merge with Switch may indeed be the way to go.
Yeah thanks, I ended up getting similar to what I mentioned above, just a lot of messing around.
