Delete multiple empty masks
paul.trivilino
Post by paul.trivilino »
My company is starting to receive PDFs from Canva. These PDFs almost always have empty clipping masks on top of all placed graphics. The mask is filled with 100% black, but the transparency is set to 0. Is there an action or global change I can run on these files that will get rid of all the masks in one action? I tried several "Remove" options and none of them worked. So I am manually selecting each mask and deleting them.
Thanks for the help,
Paul Trivilino
Print Production Designer
Firespring, Inc.
Re: Delete multiple empty masks
Can you share such a file?
Adam
Post by Adam »
I have been noticing this lately as well. A new "feature" from Canva. I tried to write an action list, but there doesn't seem to be a way to select by alpha fill %. My plan was to try to select anything with 100% black fill and 0% alpha fill and delete them.
My workaround now is using the select similar object panel, but that needs to be done on a page-by-page basis.
Hi all,
Indeed, one of the quirks of Canva. There is indeed no way (yet) to select objects based on a specific alpha %. But what we notice is that those objects tend to use the Gray Colorspace. So you could use something like:
  • Select Transparent Objects
  • Select fill color > Gray 100%
  • AND
  • Remove Selection
That should do in this particular case but there might be false positives. So to be used with care.
Also, we are working on delivering a Canva specific preflight, would you be interested in testing it?
Rob Nijland
Post by Rob Nijland »
Hi all, I'm new to the board and looking for ways to solve Canva related print problems. So yes, I would love to test a Canva file specific preflight.
loicaigon wrote: Mon Jan 27, 2025 1:22 pm Hi all,
  • AND
  • Remove Selection
If you upgrade to PitStop 25.03 or later, you will find this preflight profile part of the defaults' ones (See /Demo/Just make my Canva PDF work)
