Round pages sizes in action list
JavierLFPC
Post by JavierLFPC »
I'm creating an action list and I need to use "Changes document title" action using the current page size variable.
I know how to do it, but the size in mm I get in the document title is afected because the point calculation PitStop is based on.
For instance, if my document size is 700mm x483mm the number I get using "Change document title" (Variable %Page Box DImensions%) is 700.06 x 483.97 mm.
Is there any way to round this values or get them without this decimals addded by Pit Stop way of working with points?
Re: Round pages sizes in action list
I am afraid that is currently not possible with PitStop Pro alone.
Loic
JavierLFPC
Hi Loic,
What else is needed to do that? Switch?
Regards,
Yes Switch would indeed handle that case.
For example, the following would take the Trimbox width, convert in mm, and round with none decimals:
[Switch.Calculation:Expression="round([Stats.TrimBoxWidth:Type="Defined"]/72*25.4,0)"]
