XML to (x)HTML with Borgen Saxonica Saxon
emile.schilders
Post by emile.schilders »
Hello everyone,
I have an XML file and I want to convert it to HTML so I can print it. I want to do this using XSLT and the Saxonica Saxon app.
However, I’m not getting any HTML or XHTML output. Am I doing something wrong, or is this not possible?
Kind regards,
Emile
JimmyHartington
Re: XML to (x)HTML with Borgen Saxonica Saxon
Post by JimmyHartington »
Can you share how you are doing it now? How the Saxon app is setup?
Either a screenshot from Switch. Or document the flow and screenshot the Saxon settings there.
Or you could use Easy Data Transform instead, it's easier and you have an App for it in Switch.
https://www.easydatatransform.com/
https://www0.enfocus.com/en/appstore/pr ... sform-beta
JimmyHartington
If your use case is not just to print the XML as a table, but if it contains order info, then I have had great success with using the app Create file from template https://www0.enfocus.com/en/appstore/pr ... m-template.
The input then has to be JSON, but XML can be converted to JSON. Also with Easy Data Transform.
The example below is a simple production sheet made from a JSON-file from a Shopify order. The output is HTML and in this case used to e-mail to an external supplier.
