Copy files (job) into some directiory (Windows)
Post by dkelly »
Why not use the built-in copy function?
s.copy(srcPath, dstPath);
Post by dkelly »
Or try this
var CopyCommand = ["copy","/Y", job.getPath(), ArcSubDirOrderNumPath + + job.getName()];
var exitCode = Process.execute(CopyCommand);
As of version 12 there is separate help for Switch (started from Switch Designer) and for Switch scripting (started from Switch Scripter). That is more convenient when searching in the scripting part because you do not get unnecessary hits.
You find the copy function in the Environment class. It works with the Switch class as well, because that subclasses from the Environment class.
