Hey everyone,
Just upgraded to 25.03 and having an issue where the die line is not always removing removed from the printed output.
The Thru-cut is setup as a spot color and not a layer and its stroked. Its being picked up for the cut data but not being removed from the print data.
The only setting I know of its in the exporting of the print file where you have a check box for remove dielines which is selected.
