What is the difference between arguments and parameters?
Posted: Sun May 11, 2025 6:36 pm
I think I understand, but I would like to explain a little more.
From what I gather, these two terms are often used interchangeably, but technically they have distinct roles depending on the context.
Parameters are variables listed in the function definition — they act as placeholders.
Arguments, on the other hand, are the actual values that you pass into the function when you call it. These values are assigned to parameters.
Is that explanation correct?
