Privatedata from filename
and thank you for this forum.
I want to detect some characters at the beginning of the file name in the flow to create a “myVariable/MyPrivateData” variable, with a regex :
([0-9]{4})(-123)(.*) = "toto"
([0-9]{4})(-456)(.*) = "titi"
([0-9]{4})(-789)(.*) = "tata"
etc
Then I can use these variables as private data in the flow arrows or variable paths.
Where can I find documentation or examples about this kind of private data creation ?
I have the Scripting module but i'm not a scripting expert... Someone has examples to share ?
Or : should it be better to write an xml file with all rules to be read for each jobs ?
<rules>
<rule pattern="([0-9]{4})(-123)(.*)" myVariable="toto" />
<rule pattern="([0-9]{4})(-456)(.*)" myVariable="titi" />
<rule pattern="([0-9]{4})(-789)(.*)" myVariable="tata" />
</rules>
In this case i'm completly lost ! Possible to do this technic too ?
Thank you very much for your help
AF
etc
<rules>
</rules>
AF
Re: Privatedata from filename
Since you have the Scripting module you can use this app to add Private data to the job with scripting.
https://www0.enfocus.com/en/appstore/pr ... ivate-data
To do what you want is quite simple with scripting.
Thank you Jan,
yes this is always the same problem ! I have the Scripting Module but not enough knowledge to use it well !
I still need to learn how to script. I can't find many sources for training...
Someone knows a site for training or to download examples ?
The documentation shows some examples and give you instructions on the special functions Switch have.
There are some videos in the Learning section on the support pages on Enfocus.com
And then there is ChatGPT that can help you too.
Mention that you use Enfocus Switch in the question to ChatGPT and it knows what you are doing.
First of all, you could achieve this without scripting to the expense of more branches inside your flow.
But as you have the scripting module, you could indeed achieve your goal.
Another approach is to use this app:
But scripting is certainly needed for the logic if you want to avoid multiple branches.
But there ChatGPT provided me a script that worked in a blink and I just use it as script expression with the mentioned app.
I leave it to you to see what works the best for you.
Loic
Loic
Merci Loïc !
I am always surprised as we often need to use third parties applications in Enfocus Switch.
Can't these apps disappear or not be updated?
Thanks to ChatGPT, i finally wrote a script and it is working very well.
So proud to share it here, this is my first script ! ChatGPT was very patient with me.
Don't hesitate to correct/improve the script please !
Again, if you have sources to learn like "scripting for dummies... please share the links.
And it seems this is an old way of scripting non ? Now we must use "node.js" ?
I hope Enfocus will maintain this way of scripting...
Loïc, can you send me how you use the Add Private Data application with regular expression please?
Thank you all and for this forum
AF
function jobArrived(s, job) {
var filename = job.getName();
s.log(1, "Nom du fichier : " + filename);
// Define regex patterns and corresponding values
var patterns = [
{ regex: /^([0-9]{4})-123(.*)/, value: "toto" },
{ regex: /^([0-9]{4})-456(.*)/, value: "titi" },
{ regex: /^([0-9]{4})-789(.*)/, value: "tata" }
// Check the filename against each pattern
var matched = false;
for (var i = 0; i < patterns.length; i++) {
var pattern = patterns[i];
if (filename.match(pattern.regex)) {
job.setPrivateData("myKey", pattern.value);
s.log(1, "Correspondance trouvée : " + pattern.value);
matched = true;
break;
if (!matched) {
s.log(2, "Aucune correspondance trouvée pour : " + filename);
//important pour avancer le job
SendFileToConnection(s, job);
// Is invoked at regular intervals regardless of whether a new job arrived or not.
// The interval can be modified with s.setTimerInterval().
function timerFired(s) {
function SendFileToConnection(s, job, theFilePath) {
var theOutConnections = s.getOutConnections();
for (var i = 0; i < theOutConnections.length; ++i) {
job.sendTo(theOutConnections.at(i), job.getPath());
AF
- tdeschampsBluewest
Hi!
The script you're currently using has been written in a legacy format that will soon no longer be supported by Enfocus.
I strongly advise rewriting the script in Node.js/TypeScript. Unfortunately, GPT-based assistants won't provide much support for Enfocus-specific functions.
However, if you want better results you can usse an LLM with Retrieval-Augmented Generation (RAG) and upload the Enfocus documentation into it.
I personally tried this with Mistral, and the results were significantly better.
Here is the revised script, with added functionallity.
async function getPatterns(flowElement: FlowElement): Promise<{ regex: RegExp; value: string }[]> {
const patternProperty = await flowElement.getPropertyAsString("patterns");
let array = patternProperty instanceof Array ? patternProperty : [patternProperty]; //put it in an array if only one line provided
array = array.filter((i) => i.trim() !== ""); // Remove empty lines
const patterns: { regex: RegExp; value: string }[] = [];
for (let line of array) {
line.split("="); // split the line into two parts, the first part is the regex and the second part is the value
const regex = new RegExp(line[0]); // first part is the regex
const value = line.slice(1).join("="); // second part is the value, the join("=") is to keep the separator in case of multiple "=" in the value
patterns.push({ regex, value });
return patterns;
const fileName = job.getName();
await job.log(LogLevel.Info, `Nom du fichier : ${fileName}`);
const patterns = await getPatterns(flowElement); //get the patterns from the property, should be presented like this in switch :
^([0-9]{4})-123(.*)=toto
^([0-9]{4})-123(.*)=tata
^([0-9]{4})-123(.*)=titi
const myKey = await flowElement.getVariableAsString("myKey"); //set the key as a variable in the sscript
let value = "";
for (let pattern of patterns) {
if (fileName.match(pattern.regex)) {
value = pattern.value;
await job.log(LogLevel.Info, `Correspondance trouvée : ${pattern.value}`);
break;
if (value !== "") {
await job.setPrivateData(myKey, value);
await job.sendToData(Connection.Level.Success);
} else {
await job.log(LogLevel.Error, `Aucune correspondance trouvée pour le fichier : ${fileName}`);
await job.sendToData(Connection.Level.Error);
- JimmyHartington
Hi Thomas
Can I ask on a low practical method which documentation you uploaded.
HTML-files, pdf or other?
- magnussandstrom
I really hope Enfocus build an VS Code extension with pretrained a RAG-model (or similar). This would make writing Switch scripts really fast!tdeschampsBluewest wrote: ↑Fri May 16, 2025 10:16 am However, if you want better results you can usse an LLM with Retrieval-Augmented Generation (RAG) and upload the Enfocus documentation into it.
Hi Jimmy, i uploaded the documentation as a PDF, but i also uploaded some snippet i use for coding.JimmyHartington wrote: ↑Fri May 16, 2025 10:40 am Hi Thomas
It's a beta feature, so i'm just toying with it right now and with agent (since it's free with Mistral).
here is an example of prompt :
Create me a script for switch which will parse my filename against a set of regex/replacement value
If a regex is valid, it must create a privata data key with the replacement value, and the file trough Success connection, otherwhile in the error.Code: Select all
try {
// Define your regex/replacement pairs here
const regexReplacements: { regex: RegExp; replacement: string }[] = [
{ regex: /pattern1/, replacement: 'replacement1' },
{ regex: /pattern2/, replacement: 'replacement2' },
// Add more patterns as needed
// Get the job's filename
const jobName = await job.getName();
let modifiedName = jobName;
// Check each regex/replacement pair
for (const { regex, replacement } of regexReplacements) {
if (regex.test(jobName)) {
modifiedName = jobName.replace(regex, replacement);
// Create a private data key with the replacement value
await job.setPrivateData('ModifiedFilename', modifiedName);
break; // Stop after the first match
// Log the result
await job.log(LogLevel.Info, `Original filename: ${jobName}, Modified filename: ${modifiedName}`);
// Send the job to the appropriate connection based on whether a regex matched
if (modifiedName !== jobName) {
await job.sendToSingle('Success'); // Send to Success connection
} else {
await job.sendToSingle('Error'); // Send to Error connection
} catch (error) {
await job.log(LogLevel.Error, `Error processing job: ${error.message}`);
await job.sendToSingle('Error'); // Send to Error connection on error
}Do you like the Enfocus Apps developed by Bluewest?
Hi Aristide,
You asked for how I used the "Add private data" and scripting. As a disclaimer, this solution is not that meaningful given that you end up with a script expression anyway. As you have the scripting module, just go for a complete script.
That said, the script ChatGPT wrote for me was:
Just used with the mentioned app:
// Your imports here
// Do not remove calculateScriptExpression function. It must return a promise to the property value.
async function calculateScriptExpression(s: Switch, flowElement: FlowElement, job: Job): Promise<string> {
// Get the job name
var jobName = job.getName();
// Define your regex patterns and return values
var rules = [
{ regex: /^([0-9]{4})(-123)(.*)/, value: "toto" },
{ regex: /^([0-9]{4})(-456)(.*)/, value: "titi" },
{ regex: /^([0-9]{4})(-789)(.*)/, value: "tata" }
// Check the job name against each pattern
for (var i = 0; i < rules.length; i++) {
if (rules[i].regex.test(jobName)) {
// Match found – return corresponding value
return rules[i].value;
// Default return if no pattern matched
return "unknown";
Thank you for the details Loïc
Yes and using a script will allow me to modify it once for all flows.
Hi Thomas
About the legacy / node.js mode : did Enfocus sent a date before we must have rewrite all scripts ?
I will try to rewrite my script with node.js.
But without a very low knowledge for scripting and at level 0 in node.js concept in Switch or elsewhere...
It will take time...
Any help would be welcome !
Hi Thomas
