Lock PDF
Posted: Wed Jun 25, 2025 3:49 pm
by schmitzdp
Is there an action that locks the pdf for editing but not for printing ?
(without used the paid App PDFCrypt (https://www0.enfocus.com/en/appstore/product/pdfcrypt)
Re: Lock PDF
Posted: Tue Jul 01, 2025 12:12 pm
by tdeschampsBluewest
You can install PDFtk (https://www.pdflabs.com/tools/pdftk-server/) on your server, and use the following command, with run command app :
pdftk.exe "%%InputFilePath%%" output "[Job.NameProper].pdf" owner_pw "1512!" user_pw "1234" allow Printing
Here is a quote from the documentation, for the permission
[ allow < permissions > ]
Permissions are applied to the output PDF only if an encryption strength is specified or an owner or user password is given. If permissions are not specified, they default to ’none,’ which means all of the following features are disabled.
The permissions section can include one or more of the following features:
Printing – Top Quality Printing
DegradedPrinting – Lower Quality Printing
ModifyContents – Also allows Assembly
Assembly
CopyContents – Also allows ScreenReaders
ScreenReaders
ModifyAnnotations – Also allows FillIn
FillIn
AllFeatures – Allows the user to perform all of the above, and top quality printing.
Re: Lock PDF
Posted: Fri Jul 11, 2025 1:05 pm
by schmitzdp
I would have preferred to use Pitstop (if the function existed) or an application from the appstore.
Re: Lock PDF
Posted: Wed Oct 01, 2025 1:48 pm
by yosimo
schmitzdp wrote: Fri Jul 11, 2025 1:05 pm ...I would have preferred to use Pitstop...
As an alternative to a PitStop action list, you could do this directly with Acrobat's own Action Wizard tool and a custom Acrobat action. The screenshot shows how.
Re: Lock PDF
Posted: Wed Oct 01, 2025 3:54 pm
by loicaigon
Hi there,
A feature you can use is actually Certified PDF. if you certify the PDF, you at least "freeze" the PDF in a certain state. If the document is further modified, the certification will drop. And if recertified, you will have access to History about who dit it and when.
Icing on the cake, you can revert to the previous certified state.
This is not locking per say, but I think Certified PDFs are underestimated.
https://cdn-www.enfocus.com/manuals/Ref ... ertif.html
Re: Lock PDF
Posted: Fri Oct 24, 2025 2:28 pm
by schmitzdp
yosimo wrote: Wed Oct 01, 2025 1:48 pm
Is there a way to adapt it for Pitstop Server ? (Whether to lock it or certify it)
Re: Lock PDF
Posted: Fri Oct 24, 2025 4:10 pm
by loicaigon
You can definitely certify the PDF:
For password protecting documents, Is that really something you want to do at massive scale?
Re: Lock PDF
Posted: Mon Oct 27, 2025 11:00 am
Hi Loïc,
From here, we have quite a few customers who rely on PDFTK for this purpose.
They typically use it either for:
Proofing, by restricting permissions (allowing only viewing, but not printing or modifying the file — making it unusable for other print shops), or
GDPR-related reasons, requiring a password to open the file.
Having similar functionality built directly into PitStop Pro or PitStop Server would be very useful for us.
Re: Lock PDF
Posted: Mon Oct 27, 2025 12:54 pm
by loicaigon
Noted, thanks!
