Script Expression for dynamic Field Values
Posted: Wed Jul 09, 2025 5:06 pm
by Tenzo
Hey all,
I have a Submit point that uses lots of conditional Drop downs (If parent equals).
I understand this will show the child field/s when meeting the condition, but I am wondering instead of only the child field being dynamic, can I use a script expression to change the child field Value based on the parent value?
I am not sure what syntax to use to get the values of the parent field when selecting the option "Define Script Expression".
I am just looking to make a (switch - case) to determine the child value/s based on the parent field Value.
Is this possible?
Re: Script Expression for dynamic Field Values
Posted: Wed Jul 09, 2025 6:12 pm
by tdeschampsBluewest
The Switch client does not support referencing other field values when defining the value of field. This means you can't dynamically set a field's value based on the value of another one
One workaround is to manually create multiple child fields for each possible case and assign them the same tag. This can be used to simulate conditional logic based on the parent value.
However, this approach comes with significant limitations:
  • Requires creating one child per case (e.g. one per parent value)
  • Becomes difficult to maintain as the number of cases grows
  • Can be error-prone when accessing values within XML
There is an open feature request to address this limitation. You can upvote or comment on it to help prioritize its development.
Visit: https://my2.enfocus.com/en/switch/featurerequests
Search for: Allow Switch client variable to calculate/reuse values from parents
Posted: Wed Jul 09, 2025 6:59 pm
by Tenzo
tdeschampsBluewest wrote: Wed Jul 09, 2025 6:12 pm The Switch client does not support referencing other field values when defining the value of field. This means you can't dynamically set a field's value based on the value of another one
Feature Request
Not surprising that it isn't an option given the already know limited Submit Portal options.
Thanks for confirming this for me. I added upvoted it, added a comment, and marked it as critical. Hopefully they will start working on a better Submit portal for future releases. Thanks again!
