Customised Report Message
DJS
Post by DJS »
Hello
I am trying to get a simple message to be returned on failure
In a preflight ppp
When using CHECK ON > Page > Page size there are 3 default messages:
  • %BoxType% width is %Width%, should be %WidthComparator% %RequiredWidth%
  • %BoxType% height is %Height%, should be %HeightComparator% %RequiredHeight%
  • %BoxType% width is %Width%, should be %WidthComparator% %RequiredWidth%, %BoxType% height is %Height%, should be %HeightComparator% %RequiredHeight%
Screenshot 2025-07-17 at 11.57.17.png (169.04 KiB) Viewed 8002 times
When running this on documents I get different responses (ie 1, 2 or 3)
What dictates which response is used?
Is there a way I can override the 3 responses and only have 1?
Is there a way I can return the size, ie A5, or A4 etc (obviously %Size% isn't valid)?
Thank you
Re: Customised Report Message
If the height is correct, but the width isn't, you'll get the width message, and vice versa. If both are incorrect, you'll get the long message. You can set all three to the same custom message, but unfortunately you're probably limited to using the variables from the one message that is picked at runtime. That is: you can't use %RequiredWidth% in the height message and vice versa.
Your only option is probably to have separate profiles, one that checks for A4 and also mentions that in the custom message, one for A5, etc.
DJS
Post by DJS »
Thank you
