Nup in quite imposing without removing cropmarks
zurek
Post by zurek »
Hi guys, I’m looking for a way to run Quite Imposing sequence - nup to step and repeat that will not remove cropmarks from original file. Any idea how to achieve that? Some walkaround with Switch and pitstop will be good as well but maybe there is an easy way?
TucsonOllie
Re: Nup in quite imposing without removing cropmarks
Post by TucsonOllie »
In my testing, QI does not remove the crop marks per se, but rather clips all art to the bleed box.
So, if your marks are fully outside the bleed box, they will not be visible. If you enlarge your bleed box enough, all printer's marks will be retained, other than in your gutters.
zurek
Post by zurek »
it worked! I should have tried that earlier. Thanks
