Double Sided Different Image Banner
St3ve
Post by St3ve »
The action needed is for banners that have extra image to fold over onto the back and vice versa on the front. To have this correct means that I need to copy the image from page 2 (Back image) of a pdf and paste on page 1.
Top & Bottom copied image needs to be rotated 180 degrees and moved to the top & bottom.
Left & Right copied image needs page 2 image trim right to be on page 1 trim left AND page 2 image trim left to be on page 1 trim right.
I would love a solution where this can be as above (Page 2 image copied and moved onto page 1 AND opposite (Page 1 image copied and moved onto page 2)
I have mastered creating an action that the left and right on both pages are correct. I can action page 2 image top & bottom onto page 1.
I cannot get page 1 image top & bottom to be on page 2.
Below is the original input pdf.
Original 2 page
Original 2 page
Original PDF with 2 pages.png (209.17 KiB) Viewed 23856 times
After the actions - Attachment below shows both pages (Pages 1&2 - Left & Right correct. Page 1 - Top & Bottom correct. Page 2 Top & Bottom wrong)
Using Actions with Page 1 correct and Page 2 wrong
Pitstop Actions performed.png (196.77 KiB) Viewed 23856 times
Action List so far - Just need to work out a way to get the page 1 copied on to page 2, rotated and moved top and bottom just like what I have achieved for page 1.
Action list so far
Action list so far
Action List.png (187.07 KiB) Viewed 23856 times
I have tried so many combinations but all fail to action the page 2 as I need.
Thanks Steve :) :)
CruzinCooler
Re: Double Sided Different Image Banner
Post by CruzinCooler »
Split Action
St3ve
Post by St3ve »
CruzinCooler wrote: Fri Aug 01, 2025 5:39 pm Split Action
thank you, could you elaborate please. I had tried the split action but could only get page 1 working and not page 2. Many Thanks
Have a look at the workshop that introduces the "Split Action List":
https://learning.enfocus.com/course/view.php?id=215
In a nutshell, if you need an action list to do something backward, you would need to use "Split Action List" to "restart" processing from page 1.
This is also required if you add pages to the document for ex and when you want to act upon those new pages, you would need to use "Split Action List" to let PitStop consider those new pages as part of the document.
Robbie
Post by Robbie »
We are using this flow for doublke sides banners with fold
St3ve
Post by St3ve »
loicaigon wrote: Fri Aug 01, 2025 6:02 pm Have a look at the workshop that introduces the "Split Action List":
Thank you, will look at this
St3ve
Post by St3ve »
Robbie wrote: Mon Aug 04, 2025 8:27 am We are using this flow for doublke sides banners with fold
Dubbelzijdige banner met tunnels(verschillend beeld).eal.zip
Thank you, I have looked at this and tweaked to suit. The only thing is that Page 2 has a knocked out area where the folds are rather than taking elements from Page 1 and adding to Page 2.
Robbie
Post by Robbie »
St3ve wrote: Mon Aug 11, 2025 9:07 am
yes becouse that is the inside of the fold and we dont need an image there.
PPNINJA
Post by PPNINJA »
arrgghh pocketed banners top and bottom
try attached
Banner Action - 70mm TB.zip
(162.55 KiB) Downloaded 419 times
St3ve
Post by St3ve »
Robbie wrote: Wed Aug 13, 2025 11:34 am
Understood for pockets/tunnels but for hems I want to be able to have it correct on both sides so there are no errors on which way it is folded so need to have a solution that shows both sides with the other sides designs on the folds. Cheers though :-)
Robbie
Post by Robbie »
Wel i think if you copy step 5 and 6 in the action and change the page where it needs to copy and paste it you can do what you need. Just is een bit trying and see what happens.
St3ve
Post by St3ve »
Robbie wrote: Thu Aug 14, 2025 2:31 pm Wel i think if you copy step 5 and 6 in the action and change the page where it needs to copy and paste it you can do what you need. Just is een bit trying and see what happens.
Thank you, really appreciate the input :) :)
St3ve
Post by St3ve »
PPNINJA wrote: Thu Aug 14, 2025 4:15 am arrgghh pocketed banners top and bottom
try attached
I will have a play with this and feedback when I get chance. Thank you :) :)
