Create a PDF with multiple Database Results
Calum459
Post by Calum459 »
I am currently creating a Delivery note for one of our customers for their orders. They will be sending multiple products (separate PDFs) to us within one order, and I would like to add all of these to a single Delivery Note PDF.
Within the flow, I create Private Data from the names of the files and from the data the front-end user will enter at a submit point. I will be adding this to a database to a) record the orders we have been receiving. and B) to pull from to create different documents.
Is there a way to pull from the database all information relating to a specific number (PO Number) and add all of the data to a premade file that will enter the flow using Inject Job. I would set this up using a different add object within PitStop for each record of data but i'm not sure of any way this could be done any easier.
JimmyHartington
Re: Create a PDF with multiple Database Results
Post by JimmyHartington »
I do not have the database module, but have in other case used a JSON-file of an order.
Then used the app "Create file from template" https://www0.enfocus.com/en/appstore/pr ... m-template to generate a HTML.
This HTML is then converted to pdf to get an order sheet.
So if you are able to extract the data from the database to a JSON-file you can use this approach.
Sample JSON:
  "order_id": "ORD123456",
  "customer": {
    "customer_id": "CUST7890",
    "name": "John Doe",
    "email": "johndoe@example.com",
    "phone": "+1234567890",
    "address": {
      "street": "123 Printing Lane",
      "city": "Printville",
      "state": "CA",
      "zip_code": "90210",
      "country": "USA"
  "order_date": "2023-10-15",
  "status": "Processing",
  "line_items": [
      "line_item_id": "LI001",
      "product": "Business Cards",
      "quantity": 500,
      "unit_price": 0.10,
      "total_price": 50.00,
      "specifications": {
        "size": "3.5 x 2 inches",
        "paper_type": "Matte",
        "color": "Full Color",
        "sides": "Double-sided"
      "line_item_id": "LI002",
      "product": "Brochures",
      "quantity": 200,
      "unit_price": 0.75,
      "total_price": 150.00,
      "specifications": {
        "size": "8.5 x 11 inches",
        "paper_type": "Glossy",
        "fold": "Tri-fold"
      "line_item_id": "LI003",
      "product": "Posters",
      "quantity": 50,
      "unit_price": 2.00,
      "total_price": 100.00,
      "specifications": {
        "size": "24 x 36 inches",
        "paper_type": "Satin",
  "subtotal": 300.00,
  "tax": 24.00,
  "shipping_cost": 15.00,
  "total": 339.00,
  "payment": {
    "method": "Credit Card",
    "transaction_id": "TXN654321",
    "status": "Paid"
Sample pdf
https://d.pr/f/MDWy46
Flow
Royal TSX-Flow-server03-2025-08-04 at 14.35.50@2x.png (45.01 KiB) Viewed 4870 times
Calum459
Post by Calum459 »
Thank you for the help, I will give this a go!
Is there a way within the Database Module alongside PitStop that you know of?
JimmyHartington
You can use variables in Pitstop Server.
And these can be populated by data from Switch.
Look at this webinar: https://www.youtube.com/embed/KR_AG2_f7NE
And this latest one: https://learning.enfocus.com/course/view.php?id=608
But if you want to add multiple lines based on x amount of order lines you will probably hit a wall quickly.
Calum459
Post by Calum459 »
Perfect thank you for the help! Ill have a look at the JSON version!
