integrate quite impose & pitstop pro
dna100@012.net.il
i need solution/script that integrate quite impose & pitstop pro to one action.
- tdeschampsBluewest
Re: integrate quite impose & pitstop pro
If you want a constructive response, you may need to elaborate further
Is it a matter of convenience? Speed? Why do you struggle with two elements?
dna100@012.net.il
speed and easy use
I can see how this could be useful in Acrobat — having a one-click action, similar to Quick Run. However, I don’t think that’s realistically possible (two different editor)
From Switch, though, there is an app that helps facilitate Quite Hot Imposing (Quite helper). Beyond that, not much else.
In any case, it’s generally best to keep PitStop and Quite separate, since their logic and workflows are fundamentally different
