Execution mode no longer supported in v11
Aristide
Post by Aristide »
since v11 I get this message when I import a flow using the Execute command app :
Property "Execution mode" is no longer supported in
Execute command app from version 11. Default Execute mode is "Concurrent". Enable "Show advanced element properties" property in the flow properties pane, an extra property "Idle after job (secs)* will be available, which can be used for serialized processing.
OK this is clear, I understand. But do I have to modify something to make this message disappear permanently?
I don't have this app to update...
Even if i recreate a new flow, the message will come back when I import the flow...
I shouldn't have cared?
Thank you for the information
AF
patej
Re: Execution mode no longer supported in v11
Post by patej »
Yes, the message is annoying because we've understood it the first time it appeared, but to my knowledge there is nothing you can do before the message is removed from a new version of the app.
Aristide
Post by Aristide »
Hello Patej,
Thanks for this confirmation, I'll stop looking :-)
Have a nice day.
