Hi there,
Is it possible to save the length of a measured cut path as a variable and then use this as part of the file name?
Thanks in advance for any help.
Dan
Length of a cut path as a variable
- JimmyHartington
Re: Length of a cut path as a variable
If you have Switch it is possible.
Have an action list which check if length of cut path is less than 0.
The XML-report will then have the measured length.
This can be used as a variable in Switch to rename the file.
Thanks very much Jimmy, will give that a go.
Best regards,
Dan
Best regards,
Dan
