PDF to Tiff
Robbie
PDF to Tiff
Post by Robbie »
We having problems with some PDF files that have to many nodes in our caldera rip. is ther a (fast) way to convert a PDF file to Tiff in switch?
laurentd
Re: PDF to Tiff
Post by laurentd »
If you have PitStop Server icw Switch, you can use Enfocus PitStop Server PDF2Image.
If not, you can use Execute command icw ImageMagick.
But a better approach may be to reduce the number of nodes in the paths without changing the appearance.
PitStop offers a “Simplify line art” action for this purpose.
Also useful with cut lines.
Simplify line art.png (28.32 KiB) Viewed 49807 times
Robbie
Re: PDF to Tiff
Post by Robbie »
laurentd wrote: Thu Nov 06, 2025 1:19 pm If you have PitStop Server icw Switch, you can use Enfocus PitStop Server PDF2Image.
Tryd that already but with no result. Customer design everything in illustrator. File is not that heavy but for the rip its to much. So we making a Tiff file from the PDF and then drop it in the rip. That works.
magnussandstrom
Re: PDF to Tiff
Post by magnussandstrom »
Hi Robbie, we are also using Caldera for our LFP-production. Could you send a example file so I can try it out and maybe suggest a solution?
Malcolm Mackenzie
Re: PDF to Tiff
Post by Malcolm Mackenzie »
For high node counts you can do a node check then if over xxx raster.
Screenshot 2025-11-11 at 10.40.51.png (32.5 KiB) Viewed 49661 times
There's an option to keep text live if needed.
Malcolm
Screenshot 2025-11-11 at 10.42.27.png (16.65 KiB) Viewed 49661 times
Robbie
Re: PDF to Tiff
Post by Robbie »
I found "find complex pages (over 5000 nodes) and Rasterize them at 600 dpi". Wil try it withe that one but it takes verry long time to proces. Iif i try it in standalone Pitstop pro my acrobat is freezing and crashes.
Robbie
Re: PDF to Tiff
Post by Robbie »
Does anybody have the script for photoshop to save to tiffs? so i can put that in switch and try if that works.
JimmyHartington
Re: PDF to Tiff
Post by JimmyHartington »
Robbie wrote: Tue Nov 11, 2025 2:37 pm Does anybody have the script for photoshop to save to tiffs? so i can put that in switch and try if that works.
If that is the route you are taking, then which page box do you need to trim the file to?
The Media Box, Bleed Box or Trim Box?
Robbie
Re: PDF to Tiff
Post by Robbie »
In our case its the mediabox
JimmyHartington
Re: PDF to Tiff
I had a flow I could quickly modify. You can try that and modify to your liking.
PDF to 600 dpi TIFF.sflow.zip
(37.13 KiB) Downloaded 586 times
Robbie
Re: PDF to Tiff
Post by Robbie »
JimmyHartington wrote: Tue Nov 11, 2025 3:00 pm I had a flow I could quickly modify. You can try that and modify to your liking.
Thanks Jimmy i will give it a try.
Wil let you know
Robbie
Re: PDF to Tiff
Post by Robbie »
Im getting a script return error in the photoshop element.
JimmyHartington
Re: PDF to Tiff
Try and recreate the Photoshop action by dragging a new one and setting it with the same settings as mine.
Just so we are sure my flow does not expect at different version or anything like that.
Robbie
Re: PDF to Tiff
Post by Robbie »
JimmyHartington wrote: Wed Nov 12, 2025 7:40 am Try and recreate the Photoshop action by dragging a new one and setting it with the same settings as mine.
Still getting the same error
Scherm­afbeelding 2025-11-12 om 08.03.40.png (22.41 KiB) Viewed 49553 times
. nothing else to see whats ever wrong only this
JimmyHartington
Re: PDF to Tiff
Are there any errors in the messages for Switch for the flow, which can help pinpoint the error?
