Child job is created inside a folder
PdFUser5000
Post by PdFUser5000 »
Script input is an html document with a link to a webpage.
The script uses puppeteer webscrapper to download a zip file from the webpage.
This file is downloaded to a folder on the desktop.
Now when i create a child job from that folder, the output job is the downloaded zip file inside a job folder called "zip", since i am using that path in the createChild function.
Is this expected behaviour, since i am not downloading to a temp path? I tried to use tmp similar as in here https://github.com/EnfocusSW/webShop/blob/main/main.ts but then the function waitUntilDownload fails and the download is cancelled.
I can remove the folder with job dismantler and everything is ok, but i was just wondering if there is a way to get the downloaded zip file without the folder as a child job?
import { time } from "console";
const puppeteer = require('puppeteer');
const fs = require('fs');
const path = require('path');
const { execSync } = require('child_process');
//Get access to incoming switch job
    let inputjob = await job.get(AccessLevel.ReadWrite);
//Launch Puppeteer browser
    const browser = await puppeteer.launch({
        headless:false,
        defaultViewport: null,
   try {
//Create new page
        const page = await browser.newPage();
// Read HTML file and extract URL
        const htmlContent = fs.readFileSync(inputjob, 'utf8');
        const urlMatch = htmlContent.match(/https?:\/\/[^\s"'<>]+/);
        const url = urlMatch ? urlMatch[0] : null;
        //await job.log(LogLevel.Info, url);
        if (!url) {
            await job.log(LogLevel.Error, 'No URL found in HTML document. Url is ' + url);
            await browser.close();
            return;
// Set download path to desktop/ZIP folder
        const desktopPath = path.join(require('os').homedir(), 'Desktop');
        const zipFolder = path.join(desktopPath, 'ZIP');
        if (!fs.existsSync(zipFolder)) {
            fs.mkdirSync(zipFolder, { recursive: true });
// Configure download behavior - allow
        await page._client().send('Page.setDownloadBehavior', {
            behavior: 'allow',
            downloadPath: zipFolder
        // Navigate to URL
        await page.goto(url);
        //wait for button
        await page.waitForSelector('body > app-root > div > span > app-header > div > nav > div.download-project', { timeout: 10000 });
        // Click the "Download Project" button
        await page.click('body > app-root > div > span > app-header > div > nav > div.download-project');
// Wait for download to complete
    async function waitUntilDownload(page: any, fileName = '', timeoutMs = 60000) {
        return Promise.race([
            new Promise((resolve, reject) => {
                page._client().on('Page.downloadProgress', (e: any) => {
                    if (e.state === 'completed') {
                        resolve(fileName);
                    } else if (e.state === 'canceled') {
                        reject(new Error('Download canceled'));
            new Promise((_, reject) => {
                setTimeout(() => {
                    // ensure browser is closed on timeout, then reject
                    browser.close().catch(() => {}).finally(() => {
                        reject(new Error(`Download timeout after ${timeoutMs}ms`));
                }, timeoutMs);
    await waitUntilDownload(page, '', 60000);
    const newjob = await job.createChild(zipFolder)
    await newjob.sendToData(Connection.Level.Success);
    await job.sendToNull();
    // Remove the downloaded file
    const files = fs.readdirSync(zipFolder);
    for (const file of files) {
    const filePath = path.join(zipFolder, file);
    fs.unlinkSync(filePath);
    //Close browser
    //await job.log(LogLevel.Info, 'File downloaded to:' + zipFolder);
catch (err) {
    const errorMessage = err instanceof Error ? err.message : String(err);
    await job.log(LogLevel.Error, errorMessage);
    await job.sendToData(Connection.Level.Warning);
Re: Child job is created inside a folder
The parameter of createChild is the path that becomes the child job. zipFolder is a folder, so the new job will be a folder. You have to use the path that points to the ZIP file inside that folder. If you know the name you can concatenate it to zipFolder. If you do not, you will have to scan the contents of the folder to find the name of the ZIP file before concatenating it.
