Assemble Job - Job identifier
schmitzdp
Post by schmitzdp »
I am trying to assemble several files with the ‘Assemble job’ application. I define the assembly according to an identifier that is private data. This same private data is also used to name the folder.
However, all the files pass through without being grouped.
Does this application support private data? Or have I forgotten something?
Thank you.
magnussandstrom
Re: Assemble Job - Job identifier
Post by magnussandstrom »
What setup do you have on the following settings?
Number of files
After N minutes
Complete condition
schmitzdp
Post by schmitzdp »
magnussandstrom wrote: Fri Jan 16, 2026 3:33 pm What setup do you have on the following settings?
Number of files
After N minutes
Complete condition
Number of files : 0 (deactivated so ?)
After N minutes : 1
Complete condition : Nothing (deactivated so ?)
I want jobs to be grouped together by Job identifier after 1 minute.
magnussandstrom
I don't think you can set Number of files to 0. If you instead set Number of files to 99999999, the After N minutes have higer priority and will trigger the Assemble.
schmitzdp
Post by schmitzdp »
magnussandstrom wrote: Mon Jan 19, 2026 2:29 pm I don't think you can set Number of files to 0. If you instead set Number of files to 99999999, the After N minutes have higer priority and will trigger the Assemble.
This resolves the job assembly issue. Thank you very much. :D
